AutoCAD MEP General Discussion
*Dillon, Matt
Message 1 of 7 (107 Views)
Smiley Faces?
107 Views, 6 Replies
05-30-2003 02:59 AM
I have both ADT 2004 and ABS 2004 loaded, and I have the CAD Manager
pull-down and toolbar loaded in both. In ADT the CAD Manager toolbar is
fine, in ABS, the Display Manager, Style Manager and Visual Audit buttons
have the question mark icon indicating the image can't be found. I tried
re-compiling the mns, mnr and mnc files from the mnu and reloading but no
luck.
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
Distinguished Contributor
jmcfaddn
Message 2 of 7 (107 Views)
Re: Smiley Faces?
05-30-2003 03:20 AM in reply to: *Dillon, Matt
Sounds like you are doubling your efforts and maybe the menus have been overwritten a bit. Speaking from a BS3 stand point I am not positive on BS4, but within BS3, a full version of ADT is included. So there was no reason to install a separate copy of ADT 3.3. In fact it potentially caused problems to have both loaded.
*Dillon, Matt
Message 3 of 7 (107 Views)
Re:
05-30-2003 03:47 AM in reply to: *Dillon, Matt
True, for most people, however I must be able to support both architects and
mep engineers. I need to have an ADT that is not populated by ABS, and vice
versa. Which is why I never loaded them on the same machine in 3.3 (you
couldn't). With 2004, it doesn't seem to be a problem, except for possibly
this, which I could live with. Interesting though, since I installed ADT
before ABS, and it's ABS that is not finding the icons.
Matt Dillon
"jmcfaddn" wrote in message
news:f1690c1.0@WebX.maYIadrTaRb...
*[Autodesk], jason martin
Message 4 of 7 (107 Views)
Re:
06-02-2003 09:46 PM in reply to: *Dillon, Matt
Hi Matt -
Have you recompiled the ABS menu's (our are named different than the
standard ADT ones)?
Please post back if it doesn't work.
jason
"Matt Dillon" wrote in message
news:E219101E7D846ED45910AF98B65B47EB@in.WebX.maYIadrTaRb...
and
vice
> Matt Dillon
BS4,
to
*Dillon, Matt
Message 5 of 7 (107 Views)
Re:
06-02-2003 10:25 PM in reply to: *Dillon, Matt
I tried that first off, Jason, the ABSCadManager MNC, MNS and MNR were all
deleted leaving only the MNL and MNU files, menu unloaded from the
interface, then reloaded. No change.
Interesting. But not insurmountable. I'll just save the images from the ADT
interface and apply them as images to the toolbar buttons in the ABS
application.
Thanks.
Matt Dillon
"jason martin [Autodesk]" wrote in message
news:5D7161842532BD60699D4A35B5DEFCA7@in.WebX.maYIadrTaRb...
> Hi Matt -
> standard ADT ones)?
> jason
> and
> vice
possibly
> > Matt Dillon
> BS4,
reason
> to
problems
Message 6 of 7 (107 Views)
Re:
06-03-2003 01:01 AM in reply to: *Dillon, Matt
DOH!!
Looks like the install is missing a required .dll for those images. Do what
you did before (delete all the cad manager .mnc, mns, and mnr files) the
copy that ADTCadManager.dll and name it ABSCadManager.dll. Now reload the
menus. Image should appear.
Thanks Matt!
jason
news:93A38803385B1EC6DE0ED7C701A1900C@in.WebX.maYIadrTaRb...
ADT
> application.
> Thanks.
> Matt Dillon
*Dillon, Matt
Message 7 of 7 (107 Views)
Re:
06-03-2003 01:10 AM in reply to: *Dillon, Matt
That fixed it! Thank YOU, Jason :-)
Matt Dillon
news:1B87702869F4BF002CBDF5BD95009ED8@in.WebX.maYIadrTaRb...
> DOH!!
what
> Thanks Matt!
> jason
all
> ADT
> > application.
> > Thanks.
> > Matt Dillon
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
