I have just been given a new workstation:
Dell Precision T7610 MT (R) | Intel Xeon
E5-2620 V2 (2.10GHz) | Win 7 Pro (64Bit) | 2x
500GB SATA | 16GB (2x8GB) RAM | NVIDIA
Quadro K5000
The OS is Windows 7 64x and I am using AutoCAD 2015 MEP and Fabrication. Drawing in 2d is fine but whenever I try to do anything in 3d its fustrating slow, its a struggle to even rotate the model without it constantly vanishing and reappearing. I have turned off Hardware Acceleration and Selection Effect and it has made no difference. Does anyone please have any ideas as to why the performance is poor.
If this slowness is happening with any drawing - even small ones, then the issue is probably graphics related.
Can you check to see if your graphics card driver is up to date and a Autodesk certified driver? Please go here and select Graphics Hardware, pick AutoCAD for the product and 2015 for the release, select your operating system and graphics card manufacturer, select All and select Find.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Once the search is complete, look for your graphics card and select on that link to see if there is a certified driver for your card and if so, you can download the driver right from this site. If you have an older driver installed, please install the certified driver and then restart your computer and retest the software. If your card is not listed, then go to the manufacturer's website and download and install the latest driver available for your graphics card.
You can also try testing with Hardware Acceleration ON or OFF. Type 3DCONFIG at the command line and toggle the setting for Hardware Acceleration ON or OFF depending on it's current state and see if that makes a difference.
