how can i show the center lines in the duct that goes downwards hidden? I do have the round part of the duct that is hidden showing that way but the centerlines show as cont. lines. Does anybody have a solution to this?
Silvia
I believe that is a block. Poke around in the rise and drop styles under HVAC Objects in the Styles manager.
The centerpoint that represents where the center line goes down in a rise-drop block is mapped to a non-plot layer. It is necessary to be able to select vertical segments in a selection set. It also is handy if you need to Osnap to the center. It should not plot unless someone changes the layer inside the rise-drop block itself.
