HY
How can i unit several *.dst files? (with all layout settings, sheet properties, number , title...)
Ex:
Arhitecture.dst, hvac.dst, elektro.dst. -----> in ARHHVACELEKTRO.DST
I insert the architect project as an xref in the mep project >>
Or create an original template for Arch + MEP projects
Vitaly
how can you insert a *.dst file in (like) Xref? why is necessary?
My problem
1.dst file contains many subset and sheets.
2.dst.file contains many subset and sheets
3.dst.file contains many subset and sheets
8 dst file contains many subset and sheets.
When i want to publish pdf, i must to open every dst file.
if i can unit (1-8.dst) in a single *.dst, just a simple click to plublish pdf or plotter..
To print multiple Sheet Set use "Publish Dialog Box"
Open any Sheet Set > right click on Sheet Set > Publish Dialog Box > click the Plus button for add other files with sheets
how can you insert a *.dst file in (like) Xref? why is necessary? > To work with multiple systems
PS
You can also Save Sheet List!
Vitaly
when i save in <<< publish window / Save sheet list >>> it save in *dsd. not *dst. :(((.
i think , autocad canT to combine *.dst files.
the + button in publish window, i use it many time, but can-t help me in this case.
there is a utility on JBT World. ( http://jtbworld.com/jtb-dst-tool ) The DST tool does many wonderful things with DST file like being able to combine them into a new DST. It can also purge, rename, copy, convert to XML and back allowing more in depth editing. It's worth every cent of the $25. you can also find it on AutoDesk Exchange.
Enjoy,
Joseph Perkins
