AutoCAD MEP General Discussion
Active Member
kstokes95
Message 1 of 3 (306 Views)
scheduling the radius of conduit elbows
306 Views, 2 Replies
05-18-2012 11:07 AM
I have tried and tried but cant figure out how to create a schedule that shows the radius of conduit elbows. Does anyone have any ideas? I am using Autocad MEP 2012
BTW:  You can add a manual text property to your equipment schedule and type in the diameter.  Again, it is a manual process.
Joshua
Product Support
Joshua.Benoist
Message 2 of 3 (270 Views)
Re: scheduling the radius of conduit elbows
05-29-2012 11:47 AM in reply to: kstokes95
This ability to "automatically" schedule the bend radius of a parametric conduit elbow does not yet exist in the program. The arc diameter dimension on the part inside Content Builder is not available as an automatic property outside of Content Builder.  It cannot be added to schedules.
We do believe that this would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
If you would take the time to go here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
Please let us know your impression and if this helps.
 Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 3 of 3 (269 Views)
05-29-2012 11:47 AM in reply to: Joshua.Benoist
Joshua
Joshua Benoist, PE
Product Support
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
