Running object snaps for Core AutoCAD (osmode) are not stored in the drawing file... but in the registry... but isn't saved in the Profile (Profile Tab in options dialog).
Can someone confirm this?
How bout MEP snaps? Where are they stored? In the drawing file?
I have a request to make this part of the drawing templates...
Solved by Keith.Brown. Go to Solution.
For Core Acad, OSMODE:
From on-line help for OSMode
0 NONe
1 ENDpoint
2 MIDpoint
4 CENter
8 NODe
16 QUAdrant
32 INTersection
64 INSertion
128 PERpendicular
256 TANgent
512 NEArest
1024 Clears List of Osnaps
2048 APParent Intersection
4096 EXTension
8192 PARallel
15,359 All On
For MEP:
AECBOSMODE
0 NONE
1 Schematic Curve
2 Schematic Connector
4 Duct Curve
8 Duct Connector
16 Pipe Curve
32 Pipe Connector
64 Electrical Curve
128 Electrical Connector
256 Wire Ways Curve
512 Wire Ways Connector
1023 All On
For ACA:
Wall Justification - Registry Key:
Search for OsnapToWallJustification. There are more than one key, and I do not know which specific one.
For 2012:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A006:409\AEC\6.7\AecArchX60\Dialogs\DraftingSettings\ObjectSnap\OsnapToWallJustification
For 2013:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B006:409\AEC\7.0\AecArchCore70\Dialogs\DraftingSettings\ObjectSnap\OsnapToWallJustification
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wanted to follow up. Did the above help?
Hope you have a Great Labor Day weekend.
Joshua
This did help in one respect...
... however, I wanted to know where the settings were stored...
.... I have a user asking that these be set in the templates (dwt files).
The OSMODE I know is set on the machine and not in a drawing file.
The variable for MEP snaps is what I am asking about... where the value stored?
I believe AECBOSMODE is also on the machine and same as OSMODE.
This "template" based feature does not yet exist in the program.
We do believe that this would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
If you would take the time to go here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
Please let us know your impression and if this helps.
Joshua
This functionality is easily achieved by using lisp, extension dictionaries, and reactors. On the open event, load the variable values and on the save event save the variable values.
