AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Rooftop A/C Units
4 REPLIES 4
423 Views, 4 Replies
Rooftop A/C Units
I need to use the Gas Rooftop A/C Units MVpart, but I want to change the overall length and width of the unit and the size and locations of the duct connectors to match my catalog equipemnt cut. How do I go about doing this without chnaging the existing part sizes.
PS If this works I could then post it to any future MVpart group.
4 REPLIES 4
To modify the length and width of the parts, you need to modify the blocks
that make up the MvParts themselves.
Take a look at the tutorials under Content Tools Tutorial -> Using the
Content Builder -> Lesson 1: Creating a block-based MvPart to start to get a
handle on the creation of MvParts.
After you've been through the tutorial please post back with your questions.
jason
"Buster1379" wrote in message
news:f17866d.-1@WebX.maYIadrTaRb...
I've modified Mvpart blocks and unless I create the Mvpart from scratch again, I cannot get the mvpart to update with the new changes???
i've successfully added connectors to existing mvparts and had them update properly... I've also added sizes to existing mvparts and that has been successful. Although it took me a few times to get it right... and i'm still not really sure that I know what i'm doing... I kinda wing it... updating mvparts is one of the more complicated things i've tried to do... i feel like their should be more to it... and in the end creating something from scratch seems a bit easier... maybe because I'm less concerned about what might go wrong if i don't follow a step accurately... i only lose what i've drawn... and that never happens since i experiment with save as copies just in case. I guess my longwinded point is that this seems to be an area requiring more documentation.
If you have an MvPart in a drawing and you modify the part with content
builder, it won't update it in the existing drawing. There is already a part
definition in the drawing, adding it again would be like having two blocks
in the same drawing, with the same name, but consisting of different
primitive objects.
If you want the new part to replace the existing part you can either remove
all instances of the part then run a bldsyspurge and insert the part, or (if
all you are doing is changing the view blocks) simply replace the block
definitions.
jason
"jmcfaddn" wrote in message
news:f17866d.1@WebX.maYIadrTaRb...
”Boost
