Default or preset layer for "Revision" cloud from the Annotate Tab, Markup panel is "G-Anno-Std-Revs". Can this default layer be changed and if so, where?
Thank you
kc
Solved by rmiller1973. Go to Solution.
It is set by the layer key style defined for use in your drawing/template and is held in the Style Manager. See image below for identifying the assigned layer key style and the revision cloud setting.
