I'm having a problem with REVCLOUD.
In the old Autocad's, I was able to use REVCLOUD --> O, to turn a polyline into a revcloud.
Now when I type REVCLOUD, I'm prompted with:
Arc length set at 3.00
Arc length/<Pick cloud starting point>:
The 'O' option is no longer available.
From what I've read this should still be available in my version of Autocad (MEP 2012). Anybody have any ideas? I've been flipping through the forum and though I find alot of problems regarding turning objects into REVCLOUD, I haven't found my particular problem.
Thanks ahead of itme!
could you send me a example ?
I'm on MEP 2013 and i have no problem.
It's very strange, because NUAGEREV have only one variable system "dimscale"which can modify the appearance.
Good luck !!!
