AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
resistant elevations
1 REPLY 1
bil-with-one-L
315 Views, 1 Reply
I have a dwg with a supply elevation and a return elevation defined. sometimes when I attempt to add duct at one of those elevations it just refuses to allow that elevation... it will allow the others but not the one I want. Funny thing is... they are identical elevations... I just used a return and supply elevation for good practice. anyway... why is that happening? --
Thanks --
1 REPLY 1
jmcfaddn
in reply to: bil-with-one-L
I have that same problem. They told me to try and use a tab instead of a return after entering the new elevation value. I have yet to check that solution. The drawing I'm working in right now, allows me to use the return or a click of the mouse. So their recommended Tab button really correcting the issue, is still up in the air with me. Let me know if that fixes it for you. Otherwise there is still something going on that Autodesk needs to fix.
”Boost
