How can i Create Rectangular Eccentric duct transitions in Autocad MEP 2015 i insert Eccentric Duct From the Tool plate but that's not correct Eccentric transition that is came to me concentric transition How i try to edit from "MODIFY DUCT FITTING TOOL Dialog Box" I dont know how to get bellow mention Dialog Box. Right Click while selecting the Duct fittings no menu for this Box
When i Create 90 Digree Duct Automatically comming the elobow rectangular Elbow not the Smooth radius arc Elbow after Creating the duct i can not change the elbo from rectangular to smooth arc in the selection table i have only rectangle duct
PLease Help for this
Solved by Keith.Brown. Go to Solution.
You need to make a change to your routing preference. If you do not know what a routing preference is then take a look at the link below.
In short, a routing preference tells the software what fitting to use when routing ductwork.
You can also check out this webinar that i put on for some of my customers from the link below.
https://www.youtube.com/watch?v=IoUBJKIqeYs It is specifically for learning about routing preferences and system definitions.
To create a eccentric transition you will need to make sure that your justification is set to something different than Center. You can change your justification of your ductwork on the property palette.
