AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
property set displays N/A
1 REPLY 1
678 Views, 1 Reply
Can anyone steer me in the right direction?
I happily use label curve for dynamic pipe diameters, I have also tried (with a little sucess) to display pipe heights (as the z coordinate, I would also like to be able to display the RL as well for referece in hydraulic calcs, but havent suceeded yet)
On the attached, I have gerated a new label curve style which i was hoping would display the pipe length
All it returns is N/A. There is not much help in the on line documents
When I have played around with other property set parameters, all I can return is N/A as well
can anyone shed any light?
Pete
1 REPLY 1
info
Hi Alatier,
you have selected a pipe Object property set. To get a result, you have to attach this proterty set to the pipe, where you attached the label curve.
It doesn't do it automaticly up to version 2013.
In MEP 2014 i guess, they have added a command, whre you can do it automaticly.
In the document you see on #1 the Pipe without property, no length is shown.
After attiching the set with the marked bottom, you see onm #2 the value for length.
Joeycool
MEP 2013, 2014, 2015, 2016, 2017 (DACH)
”Boost
