I am starting to use Navigator on most jobs now
I made some changes to my system (un installed some old autocads)
Now Navigator does not have an association.
I tried to link it to autocad, but that doesnt work
I can go and find the .apj file from inside autocad and that works fine, but it is really convienient to lauch direct from double click on the project file
Any one have any clues (im not interested in going through a reinstall, I would rather put up with it and wait for Autocad MEP 2015
pete
Solved by alatier. Go to Solution.
I have solved my problem by looking at another installation
The file is xxx\program files\Autodesk\AutoCad 2015\ACA\AeclaunchCurrentProject.exe
i have added in case anyone else has the same problem
Pete
