after i installed Autocad MEP 2015, i opened a file and i found this problem with viewing MVparts:
If i insert the MVpart in a new drawing it works...
It's a solution for this?
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by VitalyF. Go to Solution.
Is it just a single file or is it all files? If it is just a single file then you can insert one of each of the mvparts that are bad into a new drawing. (This will set the style in the new drawing) Once that is done and all of the parts look correct, you can delete them and them copy the entire bad drawing into the new drawing. The incorrect parts will take on the style of the parts that looked correct and everything should be ok.
I don't have an answer as to how they got that way in the first place.
Just out of curiosity have you tried REDEFINEFROMCATALOG? I am not sure if it is going to work. Your problem is really weird in the fact that the mvpart that is displaying correctly appears to be the exact same styles as the ones that are not. This does not make sense because if they are the same style then they should be using the same geometry.
Yes are the same part and same geometry but don't work...If you try to explode the mvpart, the geometry goes right but i have a block and not a mvpart.
REDEFINEFROMCATALOG change nothing...
If you open my file, have you the same problem?
Yes, the same problem, so I think this is a defect, expect SP1
This problem is solved!
Use MEP2015 SP1
http://download.autodesk.com/SWDLDDLM/Updates/MEP/SP1/AutoCAD_MEP_2015_SP1_enu.htm
Vitaly
