Hi Slawomir
Fixture Units are picked up from a Fixture Unit Table.
Style Manager > Fixture Unit Table Definitions.
Each "row" in the Fixture Unit Table control FU for Waste, Cold Water and
Hot Water.
There is also a setting whether the fixture is Public or Private.
E.g. If I add a "Utility Sink" then Fixture Units will be picked up from
"Sink - Service".
FU for Waste will be 3.00.
If I add CW/HW connectors the way Hakan and Lars-Ake wrote, then FU for CW
and HW will be picked up as well.
There is no need to add FU to each connector, please use the Fixture Unit
Table instead.
Fredrik Andersson
Autodesk BSD QA
"Slawomir Popiel" wrote in message
news:8F95693746F1C235362622803EB92E0B@in.WebX.maYIadrTaRb...
> thanks
> sp
> "Lars-Ake Johansson [Autodesk]" wrote in
> message news:6AC30061E5C3FE365B6333EA60BC6FC5@in.WebX.maYIadrTaRb...
> > Hi,
> > If you right click on the connector for the part (not the part size) and
> > choose 'Edit', you will have the ability to edit/add the fixture units
for
> > the connector.
> > (There is a small bug here, so when you add a connector you might have
to
> > press ok after choosing the system type and then choose 'edit' again to
be
> > able to edit the FU's)
> > Regards
> > Lars-Ake Johansson
> > Autodesk BSD QA
> > news:31501D1E0C7399B81E3CC3B878E5B5CC@in.WebX.maYIadrTaRb...
> > > Hi Hakan
> > > Adding connectors is ok with me and I know how to do it. I would love
to
> > > learn how to add fixture units to the fixture. Some plumbing fixtures
> have
> > > only drainage fixture units assigned, no water units. I would like to
> add
> > > these values and then I would like to know how to construct a fixture
> AND
> > > assign fixture units. So far it looks that the fixture units are not
> block
> > > attributes.
> > > Thanks,
> > > sp
> > > "Hakan Wikemar [Autodesk]" wrote in
message
> > > news:D5D7A2D04C954314512E38A6DD2A56F6@in.WebX.maYIadrTaRb...
> > > > Hi Slawomir!
> > > > If you want to add additional connectors to a MvPart you have to
> modify
> > > them
> > > > in ContentBuilder.
> > > > Start Content Builder and navigate to the desired part.
> > > > Edit the Part and go to connectors tab.
> > > > Right-click on the top level icon/text and Select Add Pipe Connector
> > > > Choosse Flow direction, System Type and F.U.
> > > > Go down to the Connector on the desired Part Size and Right-Click -
> Edit
> > > > Now Place your connector where you want it on the Part Position -
> Normal
> > > etc
> > > > (look at the red arrow which will tell you how the connector will be
> > > placed)
> > > > Hope this Helps!
> > > > /Hakan
> > > > Hakan.Wikemar@Autodesk.com
> > > > news:242F9BCF59CF037AFFEA3B6E5DE652DC@in.WebX.maYIadrTaRb...
> > > > > corner service sink
> > > > > scrub sink
> > > > > utility sink
> > > > > are lacking any cw and hw f.u. values (neither they have water
> > > > connectors).
> > > > > On the other hand there is no such thing as faucet or shower head
> > having
> > > > > apropriate f.u. assigned.
> > > > > How I can assign cw and hv values to corner sink (or any other
> fixture
> > > > > having no such feature)?
> > > > > Thanks.
> > > > > sp
