AutoCAD MEP General Discussion
*Cox, Laura
Message 1 of 2 (406 Views)
Plumbing Fixture Labels
406 Views, 1 Replies
06-26-2003 09:42 PM
I am trying to label a plumbing fixture using the fixture label from the
palette. Tha label looks correct when in the process of inserting it but
when I accept the location for the tag all that is visible are two lines.
Can anyone tell me what I'm doing wrong?
*[Autodesk], Fredrik Andersson
Message 2 of 2 (406 Views)
Re: Plumbing Fixture Labels
09-02-2003 11:27 PM in reply to: *Cox, Laura
Hi Laura
What you see is a underlined hyphen...
This happens because default "Name" of the tag is "-".
Please see help file > Building Systems 2004 Help > Building Systems
Tutorial > Plumbing Tutorial >
Lesson 9 - Exercise 1: Adding Schedule Tags to Fixture..
The key to success is to add a name for Item during the process of adding
the tag.
If you would like "P - 1" (or anything else) as default setting when using
the Fixture Tag, try this:
1. Start Design Center and select the Custom tab
2. Browse to Imperial > Documentation > Schedule Tags > Plumbing Tags
3. Right click "Fixture Tag 4" and select Open from Pop up menu
4. On command line type "AecpropertysetDefine" and then press enter
5. Right click "MvParts-FixtureUnits-Objects" and select Edit.
6. On definition tab, select Item. Change default value from "-" to "P-1"
(or anything else)
7. Please make a backup of the drawing file before saving.
Regards
Fredrik Andersson
"Laura Cox" wrote in message
news:C4C8A47C9774E9583E0D6761F5CA5348@in.WebX.maYIadrTaRb...
> Thanks
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
