AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Piping Display in ABS
1 REPLY 1
198 Views, 1 Reply
How do you change or turn off the X's when 2line display for piping? the boss does not like this display.
Jesse Urquidi
P2S Engineering
1 REPLY 1
One method is going into Format>Drawing Setup, go to the display tab and then turn off the connectors for the line type you are using. Thing is, the fittings don't stand out as clearly doing that. What we did, was change the connector type so that we would get the proper results. Guess it all depends what you are tying to do. Mike "jesseu" wrote in message news:15779610.1083169900938.JavaMail.jive@jiveforum1.autodesk.com... > How do you change or turn off the X's when 2line display for piping? the boss does not like this display. > > Jesse Urquidi > P2S Engineering
”Boost
