Hi Rick -
Because of a defect, this is actually possible right now, but really
shouldn't be. I'm adding a wishlist item for a "supported" way to do this in
future versions, but here is a way to do it in R3 (no promises that this
will work in future versions)...
OK, this is a bit confusing, so please bare with me (and this may create
some other "issues" with display that you don't like)...
I'm assuming that you want to see you piping in "single line" display, so
you want to do the opposite of what you would think and switch to a two line
display. Actually we are going to use the haloed (hidden) line setting
provided by the 2 line display, but make it look like the single line
display. In testing this I used the simple 2 line display. For each of your
piping system definitions go into the display properties and turn off all of
the following:
Contour
Contour Haloed
Connector
Connector Haloed
Annotation
Annotation Haloed
Center Line Haloed
Insulation
Insulation Haloed
Turn On the following
Center Line
Rise Drop
Now, what's really happening is that the haloed line feature is "hiding" the
piping underneath based on the width of the piping above, so it appears that
there is a break (the break width depends on the pipe size). You may want to
turn Annotation and Annotation Haloed on depending on what you want to see.
Like I said, there is no promise of this working in the future, because it
"shouldn't" happen now.
jason martin
"Rick Grady" wrote in message
news:351AA401E4E6ADAF6F4F86992577601F@in.WebX.maYIadrTaRb...
> Hello,
> I've spent quite a bit of time looking for this answer, so I figured I'd
> ask...
> Mechanical piping drawn in 3D in the model at different elevations does
not
> show up properly in the 1-Line display. Example; crossing pipes do not
> automatically break the lower pipe. What am I missing?
> Thanks,
> Rick
