AutoCAD MEP General Discussion
Active Contributor
tompilzys
Message 1 of 5 (459 Views)
Accepted Solution
PipeObject / DuctObject
459 Views, 4 Replies
04-24-2013 12:21 AM
Is there a way that PipeObject / DuctObject will be automaticly assigned when i draw pipe/duct? It is annoying to add these properties every time after drawing.
I saw similar post with answer 3 years ago but it is not exaclty what im looking for.
kind regards
*Expert Elite*
Keith.Brown
Message 2 of 5 (449 Views)
Re: PipeObject / DuctObject
04-24-2013 03:09 AM in reply to: tompilzys
This is not possible without custom programming prior to 2014.  The good news is that with Autocad MEP 2014 you can auto attach your property sets as the object is inserted into your drawing.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Contributor
tompilzys
Message 3 of 5 (439 Views)
04-24-2013 05:31 AM in reply to: Keith.Brown
Ok, good to know, at least i can stop searching for it.
Thanks.
Active Contributor
MuirEng
Message 4 of 5 (205 Views)
01-19-2014 10:53 AM in reply to: tompilzys
Hi, I have a follow up to this question.
Experimenting with MEP 2014.
I am having trouble assigning property sets to a device style. There is a GUI for this purpose (style manager, device styles, any device general tab, property sets) but the icon for add property set is always disabled. The help option works but doesn't provide much value).
Where I want to get to is that default values for the properties are associated with a specific device style. In my case I am looking at light fixtures. What I am building towards is a library consisting of unique device style for all the common light fixtures I design with (each with an associated block). Each device style is to have parameters such as manufacturer part numbers, lumens, mounting... I certainly do not want to populate these on a device by device basis.
thanks for any insight you can provide.
Active Contributor
MuirEng
Message 5 of 5 (200 Views)
01-19-2014 12:39 PM in reply to: MuirEng
okay, I figured it out. The reason I could not add PSD to device styles is because non of my PSDs were set with "device style" checked. Once I set at least one PSD with that option then this GUI started working.
This is a pet peeve of mine with just about all software. It should tell me when I click an inactive control why it is inactive!
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
