AutoCAD MEP General Discussion
Distinguished Contributor
ebarlevi
Message 1 of 4 (540 Views)
Pipe Slope
540 Views, 3 Replies
11-16-2011 11:04 PM
Can someone tell me how to change the slope of a pipe already drawn ?
Looking at previous massages (up to 2007) I can see that the question was asked and no answer.
Perhaps Autodesk people will answer?
I confirm what kbrown said, it needs to be redrawn because all attached fittings now need to adjust for that slope angle and do not adjust automatically.
I do believe that a means to change the slope automatically would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
If you would take the time to go here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
Keith.Brown
Message 2 of 4 (535 Views)
Re: Pipe Slope
11-17-2011 03:35 AM in reply to: ebarlevi
The only way to change the slope of a pipe already drawn is the change the start or end elevation of the pipe on the properties palette.  This can be quite cumbersome if you need to change several pipes and fittings in a run.  Your best bet is to delete and redraw.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
ebarlevi
Message 3 of 4 (533 Views)
Re: Pipe Slope
11-17-2011 04:02 AM in reply to: Keith.Brown
I was afraid of that answer. I do not understand. This is a major issue during design process.
Product Support
Joshua.Benoist
Message 4 of 4 (504 Views)
Re: Pipe Slope
11-21-2011 09:57 AM in reply to: ebarlevi
Joshua Benoist, PE
Senior Support Specialist
Product Support
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
