style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Hi Rob –
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">To add a new connection type to the
catalog, you need to do a couple of things. First, the connector type needs to
appear in the following list:
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Custom_Connection_Type
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-family: 'Times New Roman'">
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> No_Connector
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Undefined_Connection_Type
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flange
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flange_Slip_On
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flange_Welded_Neck
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flange_Blind
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flange_Threaded
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Grooved
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Mechanical
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Socket
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Soldered
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Slip_Joint
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Threaded
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Welded_Butt
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Welded_Socket
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Brazed
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Glued
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Flared
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Vanstone
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Banded
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Clipped
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Set_Screw
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Compression
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Electrically_Bonded
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Note: No_Connector is retired from
R3 onwards. We use Undefined_Connection_Type in place of it.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Next, you need to add it to the list
of connection types in the domain (pipe, duct, cable tray, conduit, etc.)
specific *.apc file. For example,
let’s say you need to create an MvPart with pipe connection with a connection
type of “Compression.” In this case, open your pipe catalog using Internet
Explorer, notepad, XML-Spy, or some other xml editing tool.
style="mso-spacerun: yes"> Scroll down several pages into the file
until you see something like the following:
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><ConnectionTypeSet>
style="mso-tab-count: 1">
<ConnectionTypeEnum>Brazed</ConnectionTypeEnum>
<ConnectionTypeEnum>Welded_Butt</ConnectionTypeEnum>
<ConnectionTypeEnum>Flange</ConnectionTypeEnum>
<ConnectionTypeEnum>Glued</ConnectionTypeEnum>
<ConnectionTypeEnum>Grooved</ConnectionTypeEnum>
<ConnectionTypeEnum>Welded_Socket</ConnectionTypeEnum>
<ConnectionTypeEnum>Threaded</ConnectionTypeEnum>
<ConnectionTypeEnum>Undefined_Connection_Type</ConnectionTypeEnum>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"></ConnectionTypeSet>
Add the
desired connection type from the list at the bottom of the listed connection
types but before the </ConnectionTypeSet> as
follows:
<ConnectionTypeEnum>Compression</ConnectionTypeEnum>
The next
time you go to create fittings, the connection type will be there.
style="mso-spacerun: yes"> It will also be there in the dialog you
asked about. Note, this list does
NOT get cleaned out and created every time a catalog regen is done.
To be
rigorous, in addition to adding it to the apc file, the connection type also
should to be added to the template file under Shared Content (used as a blank
catalog when creating new catalogs) so that this connection type is in any new
catalog you may create.
Another
option would be to delete the entire list inside that catalog (between
<ConnectionTypeSet> and </ConnectionTypeSet>.
style="mso-spacerun: yes"> That would give you the entire
connection type list to choose from (even those that are inappropriate for that
domain, ie., Vanstone Flange in a pipe domain).
A little
messy
style="FONT-SIZE: 10pt; FONT-FAMILY: Wingdings; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-char-type: symbol; mso-symbol-font-family: Wingdings">
style="mso-char-type: symbol; mso-symbol-font-family: Wingdings">L
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">, but I hope this helps!
