AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
PIPE LABEL ISSUES2
2 REPLIES 2
Kayrondad
454 Views, 2 Replies
PIPE LABEL ISSUES2
Please take a look at the attached image.  When we created this drawing, the pipe labels gave the correct size and elevation, however recently we printed the drawings and noticed the pipe size was not even close to reality but the elevations were correct.
Does anyone know what is going on here?  There are massive amounts of this glitch on the drawing and we need to provide as-builts pretty quick so begging for quick assistance.  Thanks.
2 REPLIES 2
Joshua.Benoist
in reply to: Kayrondad
In the image, the tag elevation and the tooltip elevation differ by 2'-9" on both TOP and BOP.  Is the xref origin somehow moved up by 2'-9"?  It would help if you provided the host dwg and xrfe...
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Following up to see if you can attach the samples?
Joshua Benoist, PE
Global Services
Autodesk, Inc.
”Boost
