Why is it that some of my pipe is coming in single line in Navisworks? when all the other trades are fine, What am I doing wrong? or what do I need to do to fix this?
thanks
The problem is actually with Navisworks. You need to have your Navisworks operator go into their options and under File Readers->DWG/DXF uncheck the box that says Use ADT standard Configuration. What that does is force your drawing to display in the standard display configuration instead of the configuration that you drew the pipe in.
A secondary option for you is to modify the Standard Display Configuration to display pipe in 2 line. I prefer changing it in Navisworks myself.
Worked for me. You can't use the nwc that was created , but when I loaded the dwg it worked fine.
Thank you
