AutoCAD MEP General Discussion
Active Member
luv2pl191
Message 1 of 2 (595 Views)
Pipe and Fitting Schedule table
595 Views, 1 Replies
12-11-2012 06:26 AM
Can someone help me with the Tag & Schedule (pipe and Fitting) table. When I generate the table. Most of the info is just lines. Even after I hit the Add All Property Set Button.
Keith.Brown
Message 2 of 2 (528 Views)
Re: Pipe and Fitting Schedule table
12-19-2012 10:52 AM in reply to: luv2pl191
Could you please upload the drawing so that we can inspect your table and your property sets?  A straight picture is not enough to troubleshoot the issue.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
