I'm running AutoCAD MEP 2015, Windows 7 Pro.
Dell Z420 Workstation
I am working with files that are what I consider to be large in size (compared to other files I've worked on in ACAD MEP). The largest file is just under 35MB, but includes xrefs from files almost just as large. All of the files have 3D Solid, Conduit, and Structural Members.
It appears that the files are bogging the system down after a period of time, and I have to restart AutoCAD a couple of times a day. A task as simple as panning becomes can become a 2 minute wait. Another user in my office also working on this project is having the same issue (same system, but 16GB DDR3 Memory).
Is this normal? I surely thought this system would be equipped to handle relatively large and complex models.
Solved by Pothman. Go to Solution.
Your project is located on the server?
Have you tried to work on a local disk? If yes, how do you see the difference in speed?
Vitaly
Yes, the files are located on a file server. No other processes run on the server. The performance issue isn't during open/saves/auto saves only.
I'll have to test that on Monday. I'm near the end of the day and usually this time does see significant lag - I haven't used my computer nearly as much today as I have in the past.
But, just in a proactive sense - what if it's NOT the server? Then what?
... Then there is little chance to rectify the situation
Maybe somehow simplify the model, for example to convert Schedule table to AutoCAD table, etc..
...Use one system in one file...
There are many things that can contribute to slow files. Certainly a 35 meg file with additional xrefs is going to be somewhat slow. You can try adding more memory to the machine and that may help.
Also, you want to check your files for any corruption.
http://knowledge.autodesk.com/article/AutoCAD-File-Corruption
Perform an AUDIT on the file
Purge Regapps
-PURGE Regapps * N
Try to limit how many viewports are in the drawing. AutoCAD has to regenerate every viewport so the more viewports the slower it will be.
If you are in 3D views, try to stick with the shademode of 2D Wireframe
Also make sure that you check all xref files for corruption as well.
A few other things to try:
http://knowledge.autodesk.com/article/Optimize-Performance-within-Windows-7-Environments
Additionally try to convert the arch plan to DWF Underlay
>>Pothman
I have no problem with the performance, i do not have 35 mb files... ))
Those links that the above have long been known, they are not much use...
Ok here is some more information (in no particualr order).
I am in the process of applying the -purge R * N to all drawings. I will see how this affects performance and update with results.
Pothman -
Thanks for that. I think the -Purge Regapps did the trick! I applied that a week ago on all of my drawings, and I haven't noticed the issue at all this week.
