I am still having problems with display vs plotting to PDF
The display is looking ok, but the lines are missing on the PDF
My client is rejecting the outputs (correctly so) An I am at risk of losing my contract if I cant sort it
I have played with the view styles changing every variable
I can get it to plot correctly with some settings, but the text prints in yellow
Can someone help me
(The 3d objects were exported as 3d objects from revit)
The Acad file and the PDF are attached
Pete
I'm a little confused. When I bring up your PDF, I see the following attached screen shot, which looks pretty good to me, although I'm not sure what may be missing, at least the text is not yellow. This is from your PDF, which I have not changed. If this is correct, then it would appear the postcript file of your PDF creater needs to be updated or pathed to your PDF print output. Your client should be seeing the same thing.
You are trying to print the output of a revit conversion which is 3D solids/Blocks and not AutoCAD MEP Objects. Solids act this way sometimes when printed in wireframe or hidden. It will probably print correctly if you print with conceptual or something similar.
You could probably get better results from your question if you ask it on the AutoCAD forum as this is a AutoCAD specific question as none of your objects are MEP objects.
Also, since you are printing everything in 2D, you could just create linework to fill in the missing gaps. It is mostly on the elbows where it is not printing correctly. Not a great solution but it would save your contract.
Hi Keith
Thanks for your response.
I can get a proper result if the export from Revit is done as a surface rather than a solid. The problem with this comes when I need to dimension the object. There is a confusing array of elemnts to snap to and no centres of circles and the lines are broken meaning that a snap to mid might not be!
I will go back and do it all again. I was reluctant as I have 100's of pipes to re process.
My other option may be to convince my client that a 3d iso dimensioned may be suitable for QS takeoff and fabrication
I will also take your advice and post to the Autocad forum
Regards
Pete
