A few persons were busy with creating parts in our office. One of the parts contain error - please see message that you see after you make regen catalogue. How can i find which part is it exactly?
To see which part contains an error, go to the folder where your part and pipe catalogs are located. Default will be something like: C:\ProgramData\Autodesk\MEP 2014\enu\MEPContent\USI\(pipe or mvpart). In the folder, either Pipe or MVPart you will see a folder called Validate. Open that folder and inside you will see a Catalog_Regen_Summary.txt Open that and it will let you know which part is giving the error. I found the easiest way to fix the errors most times is to fix them in the XML. Once you know where to find the part in question, open the xml for that part and fix the error if it is just a duplicate ID or something similar.
I found the file. But it seems all parts are ok. The only error you can see in file attached. I dont know what can it be?
