Regarding issue 1:
When I tested the part I didn't get the predefined sizes to work. Try insert
a size where the width = 43 ", it will come in with a width of 19.5"........
Further analyze of the part shows that the dimensions for LenA1 and LenA2
(RH1 and RW1) for some odd reason isn't updated with the new values. Most
likely due to some conflicting dimension or constraints
The extrusion of the 'Sloped profile' seem to behave correctly but the main
body don't.
Laj
"B Fry" wrote in message
news:9FBAFD4EA252955CFDDAA02C113ACEEF@in.WebX.maYIadrTaRb...
> Hi,
> I am modeling a parametric curb with variable pitch and have run into two
> problems.
> 1) The current version of the curb works fine if an existing part size is
> used, however if a custom size is created in the add part filter dialog
the
> modeler does not produce the custom size on screen. The part props. will
> show the custom size but the display geometry is wrong. What could cause
> this?
> 2) If you open the above part (ECV.dwg) in content builder and try to add
> geometry on the "left plane" work plane, to create a custom profile, short
> line lengths can not be created. An example of the profile I'm trying to
> create is shown in the plain autocad file named "Profile Problem.dwg". Why
> can I not create the side with the 1" dimension?
> As you can see I have overcome #2 by changing the modeling in the part
file
> but I am curious as to why I can not create the profile as indicated.
> The drawing files have been uploaded to customer files under the subject
> "Parametric Curb"
> Any Ideas?
> Thanks,
> Shane
