Hey Martin, over the past few months this has become very useful, is there any chance you can update it to work in 2011 or tell me what I can do to make it work? Right now it works GREAT in 2010, but causes 2011 to crash hard.
Thanks!
Martin, any chance you could try to update this work with 2011? I have no idea how to modify what you have done.
Right now it works perfect with 2010, crashes 2011 and can't compute the length of elbows if I open a 2011 drawing in 2010.
Thanks!
AMAZING Martin!!! Your my conduit hero!!! I tried this in MEP 2010 and it works perfectly...I to would love to see this available for MEP 2011.
I would love to see this expanded to do the following:
- Ask for start of run (depending on where you select it gives you that length than provides the rest of the info)
- Provide unique tag identifiers
- Be able to select a parallel run
- Option to be able to have the information stored & scheduled
- Create a similar cabletray routine
and also:
- have an option to be able to change output units (current units are inches)
thanks again!!
This add-on is a step in the right direction. I hope Autodesk expands on this to provide the electrical construction community with the tools we desperatly need.
Please Martin you're our only hope...
I agree, this is a great tool! With the wish list that Optimus listed previously it would be HUGE!
There are lots of goodies for ductwork, real world electrical construction gets left behind.......
Hi all-
Sorry... the old forum system used to always email when there were replies to threads I had posted to... don't know if there are new settings, or what, that I'm not aware of, but I only seem to get notified on new(er) threads.
One of my colleagues notified me of your query here... I'll take a look...
Mike- How did you get this to work on 2010?
I recently had another app where a user reported: "then hard crashes and says there is an unknown presentation version (or something like that, the error message disappeared before I could copy it)". The issue in that case was the user had the file on a network drive instead of on the local machine.
Here are a couple of URLs explaining why this is the case
http://blog.jtbworld.com/2009/03/fatal-error-unsupported-version-of.html
I'm very happy to see that you are still around Martin. I think we are all looking forward to seeing your program expanded
C#
There is nothing (that I am aware of) that should cause it to crash in 2011... it works fine for me. Are you getting any error messages/warnings, etc.. ?
The issue with 2011 vs. 2010 elbow length computations is that elbows from the 2011 catalog are a bit more complex. In 2010, there was a single radiused sweep that defined the elbow segment. In 2011, the catalog parts have the sweep + a straight segment at both ends.
This has been updated to take into account 2011's conduit elbow definitions... I don't know if all elbows are built with the same parameters... but you should get a message if something isn't computed.
There is another command as well: ConduitRunLengthAll
This will provide a summary of all runs.. the 'All Runs' section is simply a summary of what is above.. you can copy/paste this into a text file, then open in Excel if you like.
Command: CONDUITRUNLENGTHALL
Run: 121B6
2.50 Inch Conduit EMT Set Screw US Imperial
Segment 121B6 Length 360.357791026609
2.50 Inch 22.58 Deg Bent Conduit EMT Set Screw US Imperial
Elbow 121B5 Arc 4.1381579189416 Total 14.6381579189416
Segment 121AF Length 416.149124100865
2.50 Inch 94.49 Deg Bent Conduit EMT Set Screw US Imperial
Elbow 121AE Arc 17.3161416066243 Total 27.8161416066243
Segment 121A8 Length 516.895921453864
2.50 Inch 2.38 Deg Bent Conduit EMT Set Screw US Imperial
Elbow 121A7 Arc 0.436186524991999 Total 10.936186524992
TOTAL LENGTH = 1346.7933226319
Run: 121A1
Segment 121A1 Length 342.605840599857
2.50 Inch 100.32 Deg Bent Conduit EMT Set Screw US Imperial
Elbow 12187 Arc 18.3854982374804 Total 28.8854982374804
Segment 12186 Length 269.790987598795
2.50 Inch 94.31 Deg Bent Conduit EMT Set Screw US Imperial
Elbow 12185 Arc 17.2826342771603 Total 27.7826342771603
Segment 12184 Length 334.294590036683
TOTAL LENGTH = 1003.35955074998
Run: 12188
Segment 12188 Length 342.605840599857
TOTAL LENGTH = 342.605840599857
Run: 12183
Segment 12183 Length 1341.82076882816
Elbow 12182 Arc 18.3854982374804 Total 28.8854982374804
Segment 12181 Length 269.790987598795
Elbow 12180 Arc 17.2826342771603 Total 27.7826342771603
Segment 1217F Length 334.294590036683
TOTAL LENGTH = 2002.57447897828
Run: 12160
Segment 12160 Length 705.211881199358
Elbow 1215F Arc 18.3854982374804 Total 28.8854982374804
Segment 12158 Length 269.790987598795
Elbow 12157 Arc 17.2826342771603 Total 27.7826342771603
Segment 1214E Length 334.294590036683
TOTAL LENGTH = 1365.96559134948
All Runs:
121B6,1346.7933226319
121A1,1003.35955074998
12188,342.605840599857
12183,2002.57447897828
12160,1365.96559134948
