AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Opening DWF files in MEP
8 REPLIES 8
Message 1 of 9
pikowdude2002
761 Views, 8 Replies
I use NW Simulate 2013. When I export to DWF it works fine but then when I try to attach it in AutoCAD MEP 2013 it says it cannot be opened. File format not supported.
Ideas?
8 REPLIES 8
Message 2 of 9
Pothman
in reply to: pikowdude2002
You should be able to attach a dwf file inside of AutoCAD just like you would xref a dwg file. You can't just open the dwf file using AutoCAD but you should be able to attach it. If you can't do this, can you attach the dwf file to this thread so I can test with your file?
Dave Pothier
Message 3 of 9
pikowdude2002
in reply to: Pothman
Sorry for the late reply. This project got tabled for a couple weeks. here is the DWF file and the error message.Dan
Message 4 of 9
Keith.Brown
I might be missing something but there was no file attached to the post.
Message 5 of 9
pikowdude2002
in reply to: Keith.Brown
I tried to reply via email. maybe that didnt work. here are the files mentioned before.
Dan
Message 6 of 9
Keith.Brown
I got the same error message when i tried to xref it into an autocad drawing.  I tried saving it as a dwfx and xrefing it in and got the same result.  I finally imported it back into Navisworks and saved it as a fbx drawing and then imported into autocad but nothing came thru.
Unfortunately I am out of Ideas.  Sorry i couldnt be of more help.
Message 7 of 9
pikowdude2002
Well, Thats disappointing. I was hoping for a solution.
Do you know if Navisworks Manage offers any other options? I may try to get a license for my company to see if I can make something useful out of these model. Simulate doesnt seem to be working.
Message 8 of 9
DarrenP
thats a weird one
opens up fine in Navisworks & design review but Autocad says its corrupt
no clue on this one
DarrenP
Message 9 of 9
Keith.Brown
Instead of a navisworks file can you get the original file from the contractor who created it?  You are trying to work with a file that has been converted to dwf.  To make matters worse the original file was converted to an nwc or nwd before it was converted to a dwf.  In this case it might just be better to try and obtain the original file and bring it in to AutoCAD MEP.
”Boost
