When I paste an OLE object (excel spreadsheet) in my drawing and try to plot to pdf. it will sometimes show up and sometimes not. This happens even when not modifying anything on the settings. Also, sometimes when trying to plot a dwg. with an ole object attached straight to the printer it prints the object about 25% of what is actually there. Is there certain size limitations on excel spreadsheets? Is there a driver that I need to update or missing? I use AutoCAD MEP 2014, Excel 2013, Windows 7 64bit, and Hp DesignJet500 printer.
We have the same problem!
OLE grafics on the drawings don't show up on the PDF - no matter if I use "Export PDF" or print it by using "DWG to PDF"!
It worked up to AutoCAD 2013, but in 2014 it doesn't anymore...
We had on big OLE on the drawing.
It helped to decrease the resolution in the plotter configuration!!!
What was your resolution set to in the first place?
We have ours at 300dpi, but I'm not sure if anyone tested different resolutions.
