AutoCAD MEP General Discussion
Member
Mark_TGCE
Message 11 of 12 (209 Views)
Re: OBJRELUPDATE required too often
07-04-2013 03:19 PM in reply to: Joshua.Benoist
Joshua,
I am running 2014 and still having the issues described in the OP. Are there any setting to envoke or should this be fixed out of the box?
-Mark
Valued Contributor
ctindall
Message 12 of 12 (181 Views)
07-09-2013 08:28 AM in reply to: Mark_TGCE
This issue has been resolved in AutoCAD MEP 2014!  Out of the box it does not work.... I had to set HIDEPRECISION to 1 and check "Save Hidden Lines in Drawing" under MEP Display Control tab in OPTIONS.
These changes also make the drawings generate much faster when opening drawings or changing between model and paper space.  Good job Autodesk!  Many thanks to Joshua Benoist for following through on this request!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
