I use autocad mep 2013 and when I try to use 'object viewer' there doesn't appear the command in right mousse command (3d object selected). In command line : Command: OBJECTVIEWER
Unknown command "OBJECTVIEWER".
I looked in help and there is write that: '...The Object Viewer can be started from different locations in the software.'.
If I try on different computer (same drawing, mep 2013), I can use object viewer.
Can You help me with this ?
Thank You
