AutoCAD MEP General Discussion
andys2000
Message 1 of 3 (529 Views)
Object enabler AutoCAD MEP 2010
529 Views, 2 Replies
09-02-2009 09:35 AM
Can I view and dimension objects created in AutoCAD MEP 2010 (pipes, conduits, ducts) in
AutoCAD 2007 or 2008? Readme file on Autodesk website regarding this issue is not available.
I can download object enabler but no info how to use.
Valued Contributor
Andrew_T
Message 2 of 3 (529 Views)
Re: Object enabler AutoCAD MEP 2010
09-02-2009 02:33 PM in reply to: andys2000
I'm not 100% sure but I think object enablers only work on common versions, meaning ACAD2010 with the MEP object enabler will display MEP2010 content. I don't think an object enabler written for 2007/2008 will display MEP2010 content because of drawing format changes.
*Expert Elite*
arcticad
Message 3 of 3 (529 Views)
09-02-2009 03:41 PM in reply to: andys2000
You should think of Autocad's file format as a wrapper that contains the contents of the file.
Just because you save the file in an earlier version does not mean you have altered the contents of the file.
AEC content is, mostly, not backwards compatible, mostly.
Because there are changes to the AEC content that are unique to that version.
If its modified outside of it's original version then there is no guarantee that it work properly.
When content is saved back to an earlier version, the only reliable way is to -ExportToAutocad.
This will strip the AEC content down to lines and Arcs.
And you are correct. you can not use Object Enablers from other versions.
(defun botsbuildbots() (botsbuildbots))
Post to the Community
New Post
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
