AutoCAD MEP General Discussion
menline
Message 1 of 10 (618 Views)
New MVpart with materials
618 Views, 9 Replies
08-11-2011 06:28 AM
Alle added materials are gone when I make a MVpart in the content builder from this block.
Is this normal ? and if yes is there a way to avoid this.
Menno
Active Contributor
blackeagle1245
Message 2 of 10 (616 Views)
Re: New MVpart with materials
08-11-2011 06:34 AM in reply to: menline
you mean the layers or colours?. Cause mep creates the part in one colour if you dont make special arrangements
menline
Message 3 of 10 (609 Views)
08-11-2011 07:26 AM in reply to: blackeagle1245
No I mean the material
Now the MVpart takes the color of the layer when I Render the drawing instead of the added material such as sinc, or steel.
Menno
Active Contributor
blackeagle1245
Message 4 of 10 (605 Views)
08-11-2011 07:39 AM in reply to: menline
My opinion is it just takes the layers colour what you specify while making the mvpart. If you want to see different colours, before making the mvpart just put them in one layer then change the colours part by part. Otherwise if it stays in bylayer then you will see the picture you put here.
Active Contributor
freedom1k
Message 5 of 10 (412 Views)
01-17-2013 08:11 AM in reply to: menline
Yes. We're having the same problem. I'm looking for a solution. it seems to be when the parts catalog generates the view blocks it fails to carry over the material. I went into each view 3d-block and reapplied a material to all surfaces. the MvPart still ignores the material when displaying in realistic mode or exporting to 3dDWF. Has anyone found a cure?
Keith.Brown
Message 6 of 10 (366 Views)
01-23-2013 05:35 AM in reply to: freedom1k
Materials do not transfer when creating block based parts.  You will need to reassign them after inserting the part.  It would be nice if they would allow you to attach materials to layer keys instead of layers.  This would allow the material to auto attach to the object upon insertion in the drawing.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Contributor
freedom1k
Message 7 of 10 (357 Views)
01-23-2013 06:30 AM in reply to: Keith.Brown
True Keith. But they do not seem to be created with non-block based Parts. do you have procedure? Pipes, fittings and other MEP Catalog Objects also do not have a material property. We found this the hard way when importing Models into Navisworks Simulate, all MEP objects were "black", but ACA AEC Objects were fine. We've had to re-apply materials after inserting any of the MEP Catalog Objects. It's a shame since this has to be done in every drawing and when inserting new Parts. There are a couple scripts out there to apply materials/textures to objects. It would be nice it Autodesk would provide a Material option as-with all the architectural AEC objects. Just to be clear we're refering to Surface Material, not Textual type materials like in System/Routing perference. Thanks! Kelley
Keith.Brown
Message 8 of 10 (353 Views)
01-23-2013 06:44 AM in reply to: freedom1k
All catalog objects in mep will go to a consistant layer upon insertion.  This means that they layer an object goes on is consistant between drawings.  This means that you can insert materials into your drawing and attach those materials to a layer and then all objects on that layer will be assigned that material.  The two commands MATERIALS and MATERIALATTACH will get you where you need to go.
Keith.Brown
Message 9 of 10 (352 Views)
01-23-2013 06:45 AM in reply to: Keith.Brown
I forgot to mention that if you make the changes in your template then you will only have to do it once.
Active Contributor
freedom1k
Message 10 of 10 (347 Views)
01-23-2013 06:54 AM in reply to: Keith.Brown
MATERIALATTACH was what I overlooked. Thanks for pointing me in the right direction.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
