AutoCAD MEP General Discussion
*JIC
Message 1 of 4 (140 Views)
need help fixing errors
140 Views, 3 Replies
12-14-2003 12:00 AM
I just installed BS2004 and when i start the program i get the errors
that tell me i cannot get commumication controler. i go to use help to
fix and there is no help. please help!!!!
Phil
*[Autodesk], Bo Noren
Message 2 of 4 (140 Views)
Re: need help fixing errors
12-14-2003 12:00 AM in reply to: *JIC
Hi Phil,
Is it the Communication Center that are causing the error? What are the
exact error message? What happens after you get the error; can you use the
application?
/Bosse
"JIC" wrote in message
news:A72AF8F4F3DDFBA1DE19217DE893AB1D@in.WebX.maYIadrTaRb...
> Phil
*JIC
Message 3 of 4 (140 Views)
Re:
i can use the application without a problem. the error message is about
the commucation center not connecting.
Bo Noren [Autodesk] wrote:
> Hi Phil,
> application?
> /Bosse
>>Phil
Message 4 of 4 (140 Views)
Re:
Hi Phil,
This problem has been discussed in the newsgroup autodesk.autocad.2004;
search for "communication". The problem may be related to the firewall if
you are using one.
The communication center is a tool for getting updates and product
information and announcements e t c. You can read more about it in the help
file for BS2004. Type in the keyword Communication Center in the index tab.
/Bosse
news:A24DFA5C6E7DC3AB678EA092A8523BDD@in.WebX.maYIadrTaRb...
> > Hi Phil,
the
> > application?
> > /Bosse
> >>Phil
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
