I am trying to create an FCU with hatch but the hatching does not follow the unit outline instead it only creates a rectangular hatch (please see attached). Any help will be much appreciated.
Solved by %4seasons%. Go to Solution.
What version are you using? I thought that perhaps this may be due to performance reasons, however, I tried a variety of 'complex' MvParts (i.e., "380-500 Ton Two-Stage Absorption Chiller") and they all hatched as expected in 2010-2012.
Can you upload the part in question?
Thanks for the reply.
Please see attached 2 options I made and these was all created using block-based and the display properties is 2-line. I am using MEP 2012.
Looks like you need to define the Region(s) in the top view block... see attached.
Does the hatch automatically updated when you created a region on the top view block?
I tried it but still doesnt work ( not really sure how you did it).
You probably need to force an update with OBJRELUPDATE for existing instances of the Part... new ones should hatch properly.
See: http://screencast.com/t/kqI25yu6
Unfortunately it does work smoothly on my system as you did. I have to close and open my drawing then do the command before it finally regenerate.
The model now looks fine but if you can trim the 3 nos. triangular hatch on the tip of the pipework would be great.
I suspect those trianges is because it is expecting a closed geometry, and it doesn't know what to do with the lines that extend out of the pipe connections. Shortening those lines should do the trick:
http://screencast.com/t/UHiflj8aHe
If possible I would prefer to maintain those extended lines but if there is no other solution then thats ok.
