Can you post or email the part? We'll need the .dwg, .xml, and .bmp file.
thanks
jason
"robart" wrote in message
news:f16949e.-1@WebX.maYIadrTaRb...
> having spent a considerable amount of time generating solid blocks of
plumbing fittings, i proceed to create mvparts with them and when i use
them, the first part in the list inserts as desired but all the other parts
are offset by an amount equal to a connector placement. hmmmm..... so i find
the drawing generated by ABS3 and of the block views generated, the first
part has a nice cube appearance as it should but all the other parts show
the end views correctly with the top, bottom, front and back offset away
from the insert point. investigating further, they all have the same insert
point - why would 4 of the 6 blocks be offset on 19 of the 20 parts in the
drawing? any insight would be appreciated. (all the parts have the same
configuration with the same insert point - all were made with insert at
0,0,0)
