AutoCAD MEP General Discussion
New Member
stilesrd99
Message 1 of 3 (385 Views)
MvPart connections
385 Views, 2 Replies
12-23-2005 10:59 AM
When using the Multiview Part Convert Tool, I add the connections to the part I am designing. When I tried to change a connection diameter (i.e. for a pipe connection) the connection editor refuses to take the new measurement and defaults back to the original value (1"). Going under the connection "Properties" and changing it there doesn't work either. Does anyone have any idea what I might be doing wrong?
Valued Contributor
SLDBrown
Message 2 of 3 (341 Views)
Re: MvPart connections
09-18-2012 11:26 AM in reply to: stilesrd99
I apologize in advance. I don't have a solution to this dilema. I've been waiting for someone with more MEP knowledge to reply. Since this posting, did you figure this out? If so, can you enlighten me?
Steve
Active Contributor
dallasn
Message 3 of 3 (303 Views)
09-26-2012 03:37 PM in reply to: stilesrd99
I find that if you include the inches symbol ( " ), then the entry will get rejected.
Try entering just the number?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
