AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
MvPart connections
2 REPLIES 2
stilesrd99
599 Views, 2 Replies
MvPart connections
When using the Multiview Part Convert Tool, I add the connections to the part I am designing. When I tried to change a connection diameter (i.e. for a pipe connection) the connection editor refuses to take the new measurement and defaults back to the original value (1"). Going under the connection "Properties" and changing it there doesn't work either. Does anyone have any idea what I might be doing wrong?
2 REPLIES 2
SLDBrown
in reply to: stilesrd99
I apologize in advance. I don't have a solution to this dilema. I've been waiting for someone with more MEP knowledge to reply. Since this posting, did you figure this out? If so, can you enlighten me?
Steve
dallasn
I find that if you include the inches symbol ( " ), then the entry will get rejected.
Try entering just the number?
”Boost
