AutoCAD MEP General Discussion
*Expert Elite*
Keith.Brown
Message 1 of 5 (529 Views)
Multi-View Parts loosing connectors
529 Views, 4 Replies
03-25-2013 09:31 AM
Has anyone ever encounterd multi-view parts that have lost their connectors?
I have a drawing that has custom multi-view parts that are ball valves.  The ball valves have just mysteriously lost the connectors.  I can run an audit on the drawing and the connectors will come back but the connector type is not set to Undefined and nothing will connect to the pipe.
I have enclosed a sample of the mvpart.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Product Support
pothied
Message 2 of 5 (494 Views)
Re: Multi-View Parts loosing connectors
03-27-2013 07:10 AM in reply to: Keith.Brown
I have not heard of a part just "losing" their connector information. After doing an Audit, the connector information is still not all there or correct. The connection domain is missing and should be set to Pipe. Can you offer any information on what you were doing when the parts broke?
David Pothier
*Expert Elite*
Keith.Brown
Message 3 of 5 (426 Views)
04-22-2013 03:03 PM in reply to: pothied
I got this drawing from a co-worker and they cannot recall at what point it happened.  I removed all unneccessarry information from the drawing before posting it.
I will try to keep an eye on things to try and nail down when this particular issue happens.
New Member
woodyb.wp
Message 4 of 5 (362 Views)
05-21-2013 09:58 AM in reply to: Keith.Brown
I am having the same problem. All of my valves do not have the white + to continue pipe OR the pipe connection snap.
I did an audit and while the snaps and the white + for connections are back, the connection type is unknown so the flanges won't get added and even if I add them mannually they do not connect. The WBLOCK command I think is to blame, but I can't say for sure, a test wblock on fresh insert did not strip the connection.
Is there a way to add the connection type back? The properties dialog does not seem to allow changing the value from unknown.
Valued Contributor
s.lawrence
Message 5 of 5 (302 Views)
06-16-2013 03:49 AM in reply to: woodyb.wp
I've just experienced this problem for the first time too, I had a plenum box which has worked fine for months, and now the + arrow has gone missing when I select it, making connection to it impossible. Was any solution ever found?
Stu
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
