AutoCAD MEP General Discussion
New Member
liv84
Message 1 of 3 (278 Views)
Moving from AutoCad to AutoCad MEP- templates
278 Views, 2 Replies
01-15-2009 08:54 PM
We have purchased a Revit Suite that comes with AutoCad MEP I have been using AutoCad MEP just like the same as normal AutoCad but I am now trying to learn everything MEP can do as Revit is not working out. I have downloaded the tutorials but am stuck on the template as I can't see one that helps me set that up. We have a dwt file and a standard dwg file that we have been using for years but MEP won't use this for my template. Any help would be greatly appreciated. (I am trying to do the plumbing system tutorial)
*AndrewT
Message 2 of 3 (277 Views)
Re: Moving from AutoCad to AutoCad MEP- templates
01-19-2009 09:50 AM in reply to: liv84
An Autocad template alone will not work for MEP. MEP uses different
types of displays, devices, styles, etc. that regular Autocad doesn't
understand. I'd recommend starting with an MEP Template supplied by
Autodesk and inserting your Autocad template into it.
HTH
Andrew
Active Contributor
PeterLange7168
Message 3 of 3 (277 Views)
01-19-2009 12:00 PM in reply to: liv84
I am not much further ahead of you, but you will need to use an MEP template. You can import your .dwt and .dwg into the Autodesk .dwt and it will import your styles, but it doesn't work to bring all of their catalogs into your templates.
As for layer names, you might be better off excepting the AutoCAD defaults. You can edit layer colors and lineweight, but you will have to modify the layer key style and edit each item one by one. However, once it is edited, it is saved for all projects (or until the next version comes out).
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
