I was experimenting with floating my command line and closing it. Now I can't get it back to it's original place between the Application Status Bar and Drawing Status Bar.
How do I do that?
Solved by bryce.thelin. Go to Solution.
Are you able to dock the command line at the top of the AutoCAD window? It might have been set to not allow docking. This can be edited in the CUI.
Check that LOCKUI is at zero. I'm wondering if that might be affecting it.
I wanted to follow up with you on this discussion thread. Were you able to dock the command line to the bottom of the program?
