Hello, I have duplicate the duct catalog for editing and personalyzing the duct sizes trough the Catalog Editor. I restart AutoCAD and if I go to Style Manager, HVAC Objects, Duct Part Routing PReferences I can select my modified new duct part.
For example, the standar round ducts goes from 63 mm to 1.500 mm. I want for example add a 77 mm duct size.
Then If i draw a duct with a Duct Part Routing PReferences with the new duct part, I don't see the new 77 mm dimension in the list of the diameters of the duct. How can I update this list??
Thanks you.
Solved by VitalyF. Go to Solution.
You will see new dimensions, if draw a duct in the project file
step by step:
1. Open the catalog, add a new dimension, save catalog
2. Run the project, open the file and draw a duct with new dimensions
Vitaly
Also, don't forget if you duplicated your catalog - did you double check that your active catalog is the one you changed? Check your options.
Hello, thanks for your replies.
Vitaly, Is the first time I see the Proyect Browser in your video and I don't use it till now, I'm trying to learning it. Now I'm working in a Project with 3 plants but I usually work in a plane with all the DWG refx for each plant.
Working with the Project browser, I see that AutoCAD makes different DWG with each Construct or View and If I draw a vertical duct in plant 0 and I have a view showing plant 0 and 1, this view doesn't shows the duct drawed in plant 0. Do you understand? Is there any way to see only a plant? If I work in an unique modelo with 3 DWG referedX I don't see anythin becouse the 3 DWG mixes.
