Someone played around with my settings and now I'm missing the 3d Hidden & 3d Wireframe selections in the View tab/Visual Styles section. It will show up when I pull up other drawings but when I pull up a new drawings (US imperial std) its not there. Is it in the AutoCAD setting and not in the MEP setting? How can I reset this to show these again?
I have the AutoCAD MEP 2011 edition.
I think you can edit your template and copy the missing visual styles from existing one, then save template file.
steps:
1. Open -> select dwt file, then selet the one you lost visual style (US imperial std)
2. Open an existing drawing which includes 3d hidden & wireframe
3. Open visual style manager (command: visualtstyles) in the existing drawing
4. select visual style and right click from visual style manager, then select copy.
5. switch to the dwt file, right click on the visual style manager, and then click paste.
then save dwt and exit.
when creating a new drawing from the dwt, the visual style will be included.
