Does anyone know if there is a way to prevent MEP from auto-labeling a plumbing line when drawing a new system? Sometime I have runs that have elbows and tee's that are very close together and the labels get in the way. Thanks!
Solved by Keith.Brown. Go to Solution.
When you start to route your plumbing line you can choose on the property palette to not insert a label. Or you can start the PLUMBINGPREFERENCES command and uncheck the label options.
