AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
MEP Panel Schedule Customizing
2 REPLIES 2
RJK42
933 Views, 2 Replies
I formatted my panel schedules the way we would like to see them in the drawings by going to Content - Styles - Imperial and opening the Panel Schedule Table Styles (US Imperial).dwg.
But now when I included the panel into the drawing, it does not update.  I left all of the Field data in each of the cells alone.
Attached is an image of my panel schedule. The goal is to have the description, trip amps, and the pole cells to merge to the corresponding pole.  In this case, I merged three cells to merge to represent a 3-pole breaker and two cells to represent a 2-pole, and the circuits would decent approriatley, i.e.,
1
3              Description          50          3
5
7
               Descritpion           30          2
9
......... etc
Is there a way to have the panel schedule to automatically format in this way as you define it in the circuit settigs properties??
Thanks in advance
2 REPLIES 2
Joshua.Benoist
in reply to: RJK42
I am unsure if it is possible to group the circuiits by 3-pole/2-pole, but I do have this whitepaper that may help.
Joshua
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Wanted to follow up and find out if the whitepaper was useful?
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Global Services
Autodesk, Inc.
”Boost
