AutoCAD MEP General Discussion
New Member
JasonBehring3828
Message 1 of 4 (226 Views)
MEP Components are not installing from the Design Build Ultimate thumb drive
226 Views, 3 Replies
01-03-2012 03:37 PM
Let's start out by saying I am not a CAD guy. I am an IT guy.
We recently purchased the Design Build ultimate suite.  Our guys use AutoCAD MEP and are not able to load the MEP menus or any catalog items with me having to manually copy them from an existing stand alone MEP.  What am I doing wrong?
INACTIVE_Timmy.DeAustria
Message 2 of 4 (205 Views)
Re: MEP Components are not installing from the Design Build Ultimate thumb drive
01-05-2012 09:32 AM in reply to: JasonBehring3828
In regards to your issue of missing components after installation of AutoCAD MEP, you may want to use a different installation source. Can you try using a different source during installation or when you are creating a deployment image? I would download a new setup from Subscription instead of the thumb drive that you have.
You can also try going to Control Panel and select Product > Change. Here you can add components to your installation.
Please let me know if this resolves your issue.
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
Message 3 of 4 (184 Views)
01-10-2012 05:04 PM in reply to: JasonBehring3828
I wanted to follow up whether my previous response resolves your issue. Please let me know if you need further asistance.
Timmy De Austria
jvernice
Message 4 of 4 (177 Views)
01-12-2012 04:57 AM in reply to: JasonBehring3828
I had the same problem with the the building design suite ultimate thumb drive, MEP catalogs were missing from the install options (issue confirmed by Autodesk). The only solution that worked was to download the install.
JMV
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
