AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
MEP 2013 Missing Conduit in diffrent views
7 REPLIES 7
Message 1 of 8
wtaylor
961 Views, 7 Replies
Hi, when I'm routing conduit or cable tray in a view other than 2D wireframe and cancel the command all or some of the parts will disappear. The only way i can seem to get them to show up again, other than restarting the program, is to go back into 2D wireframe. Any help would be appreciated.
7 REPLIES 7
Message 2 of 8
MichaelBussiere2
in reply to: wtaylor
Thank you for your post.  In this case and from what I have seen in the past, this typically would relate to one of the following, the object, display representations, and/or graphics system and settings on the system.  One thing that may help or at least worth a quick test would be to take your current problematic file, and then insert into a new clean and blank template file (stock)  that has all stock display representations loaded.  From here you will then be able to compare overall visuals.
If this does not render a more favorable response from the system, please navigate to the link below and generate a working system information file (NFO) for review.  This will help us better understand the system environment and offer further possible solutions to this case.  Thank you and we look forward to your reply post.
NFO Link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7491145&linkID=9240617
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 8
If all you are doing is changing your Visual Style then it is probably not a display representation problem.  Your conduit should not appear/dissapear depending on which visual style you are using.  I would check that you are using a certified video card and that it is "Hefty" enough to handle the application.  I was also start the 3DCONFIG command and select the Manual Tune button and make sure that you are using 3D acceleration.  The Enable Hardware acceleration button should be checked.  Sometimes when you install/reinstall Autocad MEP it will turn this off by default.
Message 4 of 8
petrocelli718
Try this.
Right click and END ISOLATION.
this will return you view
Message 5 of 8
wtaylor
in reply to: petrocelli718
There isn't any layers isolated to end the isolation command you mentioned. Attached is a better screenshot of the issue. The conduit is the same layer from end to end but some parts are missing in concept view.
Message 6 of 8
petrocelli718
Then it must be a different issue.
We have a problem with conduits missing
UNISOLATEOBJECTS command is what brings thing back...
Good luck...
Rick Teichler
[ab_logo]
718-752-2200
______________________________________________________________________
This message (including any attachments) is intended only for the use of the individual or entity to which it is addressed and may contain information that is non-public, proprietary, privileged, confidential, and exempt from disclosure under applicable law or may constitute as attorney work product. If you are not the intended recipient, you are hereby notified that any use, dissemination, distribution, or copying of this communication is strictly prohibited. If you have received this communication in error, notify us immediately by telephone and (i) destroy this message if a facsimile or (ii) delete this message immediately if this is an electronic communication.
Message 7 of 8
Keith.Brown
Based on the screenshots and your description of the issue I would say that it is related to your video card and other hardware.
Message 8 of 8
petrocelli718
in reply to: Keith.Brown
Burst is the only way to keep attributes after exploding
Sent from my rooted droid
”Boost
