AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
MEP 2013 - crashes when trying to edit duct or pipe placement in MVPART creation
11 REPLIES 11
Message 1 of 12
pdoan98
1227 Views, 11 Replies
Has anybody else tried to create a MVPART thru a pre-defined block and add duct or pipe connections and have Autocad crash on you?  Please see the attached image that shows the error message I receive.  Any help would be greatly appreciated.
11 REPLIES 11
Message 2 of 12
Joshua.Benoist
in reply to: pdoan98
Did you create a solid and then block it?  Or is the block used for this block base MvPart, a wireframe block?  Should start as a solid.  Not sure that this would cause the fatal error.  Have you tried making the part on a different workstation?  If it crashed on a different workstation, it may be the part.  If not, it may be something uniqwue to the original workstation.  Maybe some bad support files.  Have you tried a repair or reinstall?
Hope This Helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Message 3 of 12
pdoan98
I create a drawing and then extrude it a distance to match the mfg's drawings of the part. Then I block it out in the drawing by using the "Bmake" command. I have sent my drawing to my tech support guy at advanced solutions and am waiting to see if he duplicates the same error. On the repair or reinstall, if I choose to repair the installation, will that eliminate all my custom mvparts I have already created in this database. Thanks, Pat Doan The Cincinnati Air Conditioning Co. Office: 513-721-5622 Direct: 513-587-6116 Mobile:513-728-5178 patdoan@cincinnatiair.com
Message 4 of 12
Joshua.Benoist
A repair will not delete your custom parts.  A reinstall "could" if you are keeping the part files in same folders as AutoCAD MEP.  C:\Program Files; C:\ProgramData; C:\Users\<Profile>\AppData\Local or Roaming.  \Autodesk\AutoCAD MEP 2013.  Save your mvpart's dwg, bmp and xml files off to the side.  Then do a reinstall.
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 5 of 12
pdoan98
I checked it on another workstation and it did not crash at all.  I will try a repair first then an reinstall if that doesn't work. Can you give me more detail on how to keep my custom database before I go about reinstalling MEP?
Message 6 of 12
pdoan98
I just did a repair and I lost all my customization.  The program still crashed after the repair.  I will try to re-install and see if that works.
Message 7 of 12
pdoan98
Update....
I did a full re-install yesterday.  I was able to use the edit duct placement instead of the table properties.  As of this morning, when I start MEP 2013 it crashes when I try to use the edit duct placement. Any ideas??????
Message 8 of 12
pdoan98
Update...
I recevied an email from Josh and followed the steps that was provided to me.  As of right now, I am able to use the edit duct placement.  I will keep you guys informed to how long this works or until it breaks again.
Thanks for the help.  I forward to my tech support guy at ADvanced Solutions as well so he can help others users like myself.
Message 9 of 12
pdoan98
When I logged on this morning and started MEP, the crash came back.  Any more ideas???
Message 10 of 12
pdoan98
I received instructions from Josh about doing a "clean" uninstall and re-install.  I followed the steps and was able to edit duct placement graphically.  The next day, after I shut the machine off, and began to edit duct placement on a part, the system crashed again.  I do not want to go thru the lengthy procedure everytime just to be able to edit duct placement on a mvpart I have created.  Any more ideas????
Message 11 of 12
Joshua.Benoist
Thought I would put an update on this forum thread:  I have been working direct with Patrick on the side.  We resolved his issue.  When the command line in 2013 is closed, and you go to add connectors to the mvpart inside content builder, it crashes.  We found that when the command line is on and visible, Content Builder does not crash when placing connectors on a new block based mvpart.  That's the short-term solution.  Our developers are working to address this for a long-term solution.  Others may run into this crash and thought this may help.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 12 of 12
mwooldri
in reply to: Joshua.Benoist
Hello, has there been any update on this issue?
Thank you.
”Boost
